aaronyen
1 year agoHow to control max v of arria10
I used Arria10 GX FPGA Development Kit. For some reason the power supply was unstable. Can I configure the MAX V power settings to control the voltage limit? Could you give me some solution? thank...
FakhrulA_altera
1 year agoHi aaronyen,
You may check the sub-topic: 10.7. Power Sequencing Considerations for Arria 10 Devices in this document: https://cdrdv2.intel.com/v1/dl/getContent/666662?fileName=a10_handbook-683461-666662.pdf
Also please check whether all power rails are within the required spec. Refer:
Intel® Arria® 10 Device Datasheet
Fakhrul
