DDomm1
7 years agoHow to configure Cyclone 10 LP with Active Serial Configuration?
I have a custom board with a Cyclone 10CL016 and EPCQ16A. I can generate a .pof file from Quartus and using a USB Blaster I can program the EPCQ16A. But the Cyclone 10 never configures when I apply p...
YuanLi_S_Intel
7 years agoHi David,
Since you are programming the programming file to EPCS4 / EPCQ16 directly, i would suggest to generate RPD file (in big endian order) and then have it programmed to EPCS4 / EPCQ16. Can you give it a try?
Below is the method to generate RPD file:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd11182013_802.html
YL
