9 years agoHow to apply External clock to DE2 board
Hi, I would like to apply External clock to DE2 board. But I can't use a function generator because it does not take an SMA wire. What can I do???? Please help. Thanks! Also how to use oscilloscope?????http://www.alteraforum.com/forum//images/icons/icon5.png
1 Reply
Hello Horzan667,
It could be that i did not understand your question very good but: The DE2-115 has 2 SMA connections, one for clock in and 1 for clock out. You can use these. If your clock frequency is on te low side you could also use a GPIO pin to connect the clock to a simple digital input of the fpga. I would advise to use this clock signal to drive a PLL and then use the output of the pll to do the rest of the job. Best Regards, Johi.
