how I can fix LABs requirements? I use the DE1_soc board, OS is ubuntu 18.04, and the intelFPGA_18.1 standard version. when I was trying to Compiling for FPGA then the following error generated.
Based on my knowledge, you may need to remove some logics to optimize and fit your design.
Is there any other error during your compilation?
- GTese6 years ago
Thanks!
I have optimized my kernel code and it work now.
The other error when I try to compiling as emulator the following error was generated.
aocl-clang: error: unable to execute command: posix_spawn failed: No such file or directory
aocl-clang: error: linker command failed due to signal 1 (use -v to see invocation)
aocl-clang: note: diagnostic msg: Please submit a bug report to http://llvm.org/bugs/ and include command line arguments and all diagnostic information.
aocl-clang: note: diagnostic msg: Error generating preprocessed source(s) - no preprocessable inputs.
Error: Optimizer FAILED.
Refer to My_Kernel/My_Kernel.log for details.
