ABenj2
6 years agoHow do I make the u-boot semi-hosted on IntelFPGA Cyclone5SoC development kit?
I am developing Cyclone5SoC based card which do not have a uart. Hence, I am checking if I can debug/use the u-boot semihosted. I know this feature exists for Arria10SoC as described here: http...
EShar1
6 years agoHello el.ign,
I am the distributor embedded specialist who is following on the customer.
Regarding your line above, quoting:
"As mentioned the guide demonstrated the Uboot to be loaded from Ds-5, and shows it is semihosted."
Well, I believe the clame for semihosted uboot is a mistake:
If you go the section 5. ("configure the terminal settings") of the link you shared (https://rocketboards.org/foswiki/Documentation/LoadingUBootFromDS5),
you can notice the terminal setting are for REAL serial port and not a JTAG port.
The customer is looking for a way to make to u-boot print messages to the jtag port exactly as it is available for the preloader,
and simlarly to what is demonstrated in the following link for Arria10SoC:
