YBenN
7 years agoHow do I build a simple video test pattern?
Hi I am trying to generate a simple test pattern using the PLATFORM DESIGNER with the TEST PATTERN GENERATOR IP. Can anyone refer me to an example of that kind of a system build in the QSYS/PLATFOR...
BoonT_Intel
7 years agoHi Sir,
In platform designer, you can see under 'connections' column, it allow you to tick on the dot to connect the data. If the connection is not exist, you can go to 'Export' column and double click to export. Then it will export to the Qsys top level and you can connect it from there.
