How can you use multiple instantiations of the same partition and synthesis qdb file?
Could you upgrade to the newer version of the software and see if the problem persists? Could you share the error message?
- DBay6 years ago
No, unless I can be assured that there is a real fix for this issue, I can't afford to upgrade. Based on previous experiences, it can take years to fix a problem like this.
Error(18781): Deterministic overuse of FF resources in region (96, 183) to (120, 199)
Info(11579): Estimated usage is 6948 resource(s).
Error(16297): An error has occurred while trying to initialize the plan stage.
This is the last setup. I had just the two partitions imported with no LL regions specified for the partitions yet. I think it was a similar error when I made LL regions for each partition that was imported. Each of these partitions probably had a dozen partitions within them in a hierarchical format from several projects deep.
