CEnde
7 years agoHow can we generate a design for FPGA2 on Stratix V Advanced Systems Development Kit without any timing violations within the DDR3 SDRAM Controller IP Component?
We're using the Stratix V Advanced Systems Development Kit for video processing and got a fundamental timing problem with the second FPGA on this board. Both FPGAs run almost exactly the same design ...
CEnde
7 years agoThank you for your reply! Your explanation sounds plausible to me, although I was hoping for an error case with a simpler solution.
Since there is a clear difference in performance between both Stratix V FPGAs, we assume that these problems have a crucial impact on our use case.
