Timmio
6 years agoHow can I use the HDMI Tx port on Arria V GX Starter kit?
Hi all, I wanted to use the HDMI Tx port on Arria V GX Starter kit, so I declaired the TMDS output pins and assigned the pins as: HDMI_TX_CLK_P: PIN_AC3, 1.5-V PCML HDMI_TX_CLK_N: PIN_AC4, 1.5-V P...
- 6 years ago
I used NIOS II Command Shell and executed quartus, then opened the project.
I generated the example again.
Finally, I had generated the example codes.
Thank you so much.
Timmio
6 years agoHi,
Thank you so much.
