LFang7
7 years agoHow can I simulate dedicated high speed clock input pins in HyperLynx by FPGA's IBIS model?
Hi, I download EP4SE530's IBIS model, but I can not find the dedicated high speed clock input pins in the model. The pin name is CLK[1,3,8,10]. So how can I simulate dedicated high speed clock in...
- 7 years agoHi Fang Longyu, There is no dedicated IBIS model for these pin. Since the I/O Standard in Intel PSG FPGA is programmable, you may use the I/O standard that you choose for that input clock pin as the IBIS model. Example: if you use 2.5V I/O standard, you can use 2.5Vcmos IBIS model. Regards, YL
YuanLi_S_Intel
YL
