LAthu
7 years agoHow can I build the Angstrom Linux kernel and root file system for a CycloneV SoC device?
I have to generate a Linux Angstrom image and root file system (rootfs) for the CycloneV SoC device. I have a hardware background and do not have much familiarity with Linux. I was following the Rock...
SDabh
7 years ago@LAthu and @EberL_Intel I am also facing the same problem and I have tried solution suggested by you. But it didn't work for me. Please let me know if you find any solution.
Thank you,
Sunil
EBERLAZARE_I_Intel
7 years agoHi,
There is a tutorial on compiling the Angstrom and root file system, if the above solution didn't help:
https://github.com/robertofem/CycloneVSoC-examples/tree/master/SD-operating-system/Angstrom-v2013.12#4---compile-and-u-boot-kernel-and-root-file-system
Regards.
