AIbra11
6 years agoHow am I inferring latch in this code?
I'm getting warning 10631 in Quartus II (inferring latches) Warning (10631): VHDL Process Statement warning at U6D2CPUSeq.vhd(947): inferring latch(es) for signal or variable "RST_RSMRST_N_200MS_DEL...
MEIYAN_L_Intel
6 years agoHi,
The warning is due to you had assigned statement RST_RSMRST_N_200MS_DELAY <='1' when RST_RSMRST_N_200MS_CNT = "1100100" but you do not assign new value for RST_RSMRST_N_200MS_DELAY if RST_RSMRST_N_200MS_CNT is not equal to "1100100".
You may refer to the information as below:
https://www.intel.com/content/www/us/en/programmable/quartushelp/current/index.htm#msgs/msgs/wvrfx_l2_vhdl_id_in_comb_process_holds_value.htm
