MDavi14
7 years agoHost Pipes OpenCL
Hi, I am working with an Stratix 10 GX development kit, and I have a problem with the example design loopback_Host Pipe. When the host communicate with the OpenCL command clSetKernelArg(kernel, 0, s...
KennyT_altera
7 years agoDid you get the example in
https://www.altera.com/support/support-resources/design-examples/design-software/opencl/gzip-compression.html
https://www.altera.com/support/support-resources/design-examples/design-software/opencl/host-pipe.html
May I know which version of compiler that you were using? Host channel is not supported on the later versions of the compiler, but it is available on 17.0 and 17.1.
MDavi14
7 years agoThe source code that I used is the example in:
https://www.altera.com/support/support-resources/design-examples/design-software/opencl/host-pipe.html,
The aocl version is:
aocl 18.1.0.222 (Intel(R) FPGA SDK for OpenCL(TM), Version 18.1.0 Build 222 Pro Edition
That means, the 18.1 do not have support for the host-pipe example such as the software and hardware requirements suggest?.
- KennyT_altera7 years ago
Yes, I would suggest you use the example design base on the software requirement.
