SUrba3
6 years agoHi, What are the tolerances for the 5AGXMB7G4F35C5N BGA package or where can i find them? Especially the height tolerances including the BGA are needed.
I would like to connect the mentioned FPGA via a gappad to a cooling frame. The FPGA is so to speak "pressed" to the frame. The force is brought by many srews. Therefor the compression of the gappad ...
NurAiman_M_Intel
6 years agoHi Sven,
The dimension also valid after soldering. Hence you can refer to the same pdf link for tolerances after soldering.
Aim
