MFort6's avatar
MFort6
5 years ago
Hi i am implementing a HDMI module, everything went well when i am assigning the pins and simulating it i am getting an error and i am unable to get around.
kit : Arria V GX 5AGXFB3H4F35C4N
Code:
module HDMI_test(
input pixclk,
output [2:0] TMDSp,
output TMDSp_clock
reg [9:0] CounterX = 0;
reg [9:0] CounterY = 0;
reg hSync, vSync, DrawArea;
reg rst = 0;
always @(posedge pixclk) DrawArea <= (CounterX<640) && (CounterY<480);
always @(posedge pixclk) CounterX <= (CounterX==799) ? 0 : CounterX+1;
always @(posedge pixclk) if(CounterX==799) CounterY <= (CounterY==524) ? 0 : CounterY+1;
always @(posedge pixclk) hSync <= (CounterX>=656) && (CounterX<752);
always @(posedge pixclk) vSync <= (CounterY>=490) && (CounterY<492);
wire [7:0] W = {8{CounterX[7:0]==CounterY[7:0]}};
wire [7:0] A = {8{CounterX[7:5]==3'h2 && CounterY[7:5]==3'h2}};
reg [7:0] red, green, blue;
always @(posedge pixclk) red <= ({CounterX[5:0] & {6{CounterY[4:3]==~CounterX[4:3]}}, 2'b00} | W) & ~A;
always @(posedge pixclk) green <= (CounterX[7:0] & {8{CounterY[6]}} | W) & ~A;
always @(posedge pixclk) blue <= CounterY[7:0] | W | A;
wire [9:0] TMDS_red, TMDS_green, TMDS_blue;
TMDS_encoder encode_R(.clk(pixclk), .VD(red ), .CD(2'b00) , .VDE(DrawArea), .TMDS(TMDS_red));
TMDS_encoder encode_G(.clk(pixclk), .VD(green), .CD(2'b00) , .VDE(DrawArea), .TMDS(TMDS_green));
TMDS_encoder encode_B(.clk(pixclk), .VD(blue ), .CD({vSync,hSync}), .VDE(DrawArea), .TMDS(TMDS_blue));
wire clk_TMDS, DCM_TMDS_CLKFX; // clk x 10 = 250MHz
TMDS_clk uut (
.refclk(pixclk), // refclk.clk
.rst(rst), // reset.reset
.outclk_0(clk_TMDS) // outclk0.clk
reg [3:0] TMDS_mod10=0; // modulus 10 counter
reg [9:0] TMDS_shift_red=0, TMDS_shift_green=0, TMDS_shift_blue=0;
reg TMDS_shift_load=0;
always @(posedge clk_TMDS) TMDS_shift_load <= (TMDS_mod10==4'd9);
begin
TMDS_shift_red <= TMDS_shift_load ? TMDS_red : TMDS_shift_red [9:1];
TMDS_shift_green <= TMDS_shift_load ? TMDS_green : TMDS_shift_green[9:1];
TMDS_shift_blue <= TMDS_shift_load ? TMDS_blue : TMDS_shift_blue [9:1];
TMDS_mod10 <= (TMDS_mod10==4'd9) ? 4'd0 : TMDS_mod10+4'd1;
end
OBUFDS OBUFDS_red (.I(TMDS_shift_red [0]), .O(TMDSp[2]));
OBUFDS OBUFDS_green(.I(TMDS_shift_green[0]), .O(TMDSp[1]));
OBUFDS OBUFDS_blue (.I(TMDS_shift_blue [0]), .O(TMDSp[0]));
OBUFDS OBUFDS_clock(.I(pixclk), .O(TMDSp_clock));
endmodule
  • Deshi_Intel's avatar
    Deshi_Intel
    Alright, I can see that you faced Quartus fitter compilation error.
    From the pin planner assignment, I can see that you mix up 2.5V and 1.5V IO standard for the same HDMI pins.
    • Ideally, all HDMI pins should be set to 1.5V PCML and not to be mixed with 2.5V IO standard, right ?
    One quick suggestion is you can remove you pin assignment setting and let Quartus auto fit the pin assignment for you as reference . Then only you modify from there.
    But if you need my help to really nail down the fitter error issue then I need your help to archive your Quartus design into *.qar file and share with me to review which path goes wrong in your design.
    dlim
    Deshi_Intel
    HI,
    I have not hear back from you after my last feedback on May 29.
    Hopefully you already resolved the fitter issue and able to proceed with you project development
    For now, I am setting this case to closure first.
    Feel free to file new forum thread if you still have enquiry in future.
    dlim
