hi,3c120n_88e1111 no data trans.
hi ,friends,
I have a problem, when use the 3c120n development board,the 88e1111 IC only can receive,but not send. I see the receive timing f 5 5 5 5 ... 5 d + ipv4. and I send IPv4 frome 88e1111 to ethernet ,but no data is recieved in computer. what's "f 5 5 5 ... 5 d" why data can't be sended?9 Replies
oh ,i use md_dio and md_dc pin(config6[2] set 0) ,phy_address"10010",register address"0x14",and read registers 0x14 data "0xffff".
I think it is my error,but I can't find where the error is !! - Altera_Forum
Is the address of the PHY is correct? I think the PHY is connected to the "00000" address. You can download the web server reference design and test it.
the phy address is ok,I kown what's happen ,the mac is no license,sof is old。
--- Quote Start --- the phy address is ok,I kown what's happen ,the mac is no license,sof is old。 --- Quote End --- I don't understand what have You said :confused: - Altera_Forum
I use ip core of the triple speed ethernet,but it isn't permited ,so when I can not generate .sof and .pof .
AFAIK quartus allows to generate a time-limited .sof file. At least mine quartus does, but I have to leave JTAG connected. What quartus software do You use?
quartus 9.1 and nios 9.1, altera ip core is less。
Update Your software and also update Your licences. This will allow time-limited .sof file generation and also newer (less bugs) ip cores.
quartus 10 is ok?
