19 years agoHelp!Stratix II EP2S60 DSP Development Board
Following the manual, I have downloaded the .hexout file to the flash on the board with the flash programmer of NIOS II, but when I shut down the board and turn on it again, the .hexout file download...
14 years agoI vaguely recall there are toggle switches on the board that select the configuration source. Did you check they are setup correctly?
Why do you care about the factory configuration? Its really not that exciting. If you need an example design, just ask. I have the kit. Cheers, Dave
