18 years agoHelp with Santa Cruz to HSMC Converter
board: CIII DSP Development Kit daughtercard: Bitec Santa Cruz Camera (Uses ov5620 chip) interface: Terasic Santa Cruz to HSMC Adapter board (THDB-H2S) The camera is firing up fine....
18 years ago --- Quote Start --- Apart from using a suitable logic level, I2C requires also strong pull-up resistors and a bidirectional level-translator at least for SDA. This isn't a matter of using a particular FPGA I/O pin but of a right hardware design with the HSMC to Santa Cruz adapter. I can't see from your post, if the I2C requirements are met. --- Quote End --- This is strange, I was told repeatedly from multiple sources that I2C required WEAK pull-up resistors. Perhaps this changes with the alternate interface? The level translators are bi-directional and should not be the problem. Thanks
