18 years agoHelp with Flash memory reading
hi, I am new to digital design and FPGAs, and I am having trouble with the flash Memory on the Cyclone II development board. I am playing around with a simple (6502) based cpu core (actual...
18 years agoI set this:
assign CE = 0; assign WP = 1; assign RESET = 1; assign BYTE = 1; assign Adress = 1; to fixed levels because at the read and write operation they have the same level... If i set the switch SW_OE = 0 and SW_WE =1 i expect that the Data hBDE7 was set at Adress 1 in de flash...when I then pull the switch SW_OE to 1 and the SW_WE to 0 I expect that he gives the Data (hBDE7) to the LED's SW_OE is connected with OE and SW_WE with WE... how would the code looks like, when I want to read it? I mean...when I set at the Data 16'bz how can I read then the data again from Data? I mean...I set it with z...do you know what I mean?
