10 years agohelp with ethernert plz
hi,
i need to send and recive udp data between the altera de2 to pc. i able to send data form the de2 to pc. but i cant send data form the pc to the altera. plz help :-(1 Reply
You can try to connect the transmitter to the receiver and check if the board can read its own output. You could use a sniffer to check the packets on the pc side. Bfore that, check your addresses and cables.
