15 years agoHELP!!! Qsys PCIE miss interrupt
I run the "PCI_Express_in_Qsys_Example_Designs" sample on "Cyclone IV GX starter kit" board. Running SGDMA successed. I want to know wheather DMA is ended by using interrupt. But i can't get ...
13 years agoWhat version of Quartus are you using?
Some of the earlier versions (11.0 ....) had problems with interrupts, if you search my posts in the forums you'll find where I've described the problems I've had. I think that 12.0 and later versions are working OK. Nial
