Hello, I've replaced cyclone 3 fpga with cyclone 5. But I'm confused pin assignments I made. Q1) Is there any way to verify pin assignments I've done? Q2) Can quartus prime used for verifying pin assignments? Thanks in Advance!
- 6 years ago
In that case, you can follow here:
https://www.intel.com/content/www/us/en/homepage.html -> product -> FPGA and Programmable device -> cyclone V(example) -> Documentations and Support ->
Cyclone V Device Family Pin Connection Guidelines (PDF)
Do this for the same for cyclone III for comparison. After review the above, iF Quartus able to compile without any timing error and Fitter error. it should be good to go.
Are you using a devkit? Usually, you will need to look into the user guide for each of the pin assignment usage.
For example you can take a look into: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/rm_cvgt_fpga_dev_board.pdf page 225
https://www.intel.com/content/www/us/en/programmable/products/boards_and_kits/dev-kits/altera/kit-cyclone-v-gt.html
Thanks @KennyT_Intel for the reply.
I'm not using devkit.
I replaced EP3C5E144C8N (cyclone 3) with CEBA2F23C8N (cyclone 5). I 'm a bit confused about pin assignments. So need a way to verify pin assignments I've done.
Kindly help.
