AHart2
7 years agoHello, is there an know problem with the 1000Base-X autonegotiation in the PCS_PMA unit of the triple speed ethernet mac ? Best regards, Andre
The design is compiled with Quartus 16.0 for CYCLONE V SOC with transceivers I follow the PCS initialization scheme suggested in the TSE user manual and have already tried the workaround suggested...
Deshi_Intel
7 years agoHi Andre,
There is too many design changes from one Quartus version to another Quartus version. The Quartus release note doc won't be able to track all the low lower design fix detail.
Regarding the KDB fix update - Unfortunately this was old 2012 KDB case where the original issue database was already obsolete in Intel and therefore there is no way to track back the exact version that contains the fix.
Therefore, I can only recommend to you to upgrade to latest Quartus version like v19.1 or v19.2 if possible.
Another thing to check with you is have you completely isolate this is due to auto-negotiation feature issue where there is no concern from board design signal integrity or cable issue ?
Eg : like did you disable auto-nego feature and fix the Ethernet speed and everything is working fine ?
Eg : or at minimum ensure Ethernet traffic flow is working with TSE internal loopback enable ?
Other debug suggestion will be to cross check your design with TSE IP reference design in below link
https://fpgacloud.intel.com/devstore/platform/14.0.0/Standard/triple-speed-ethernet/
dlim
AHart2
7 years agoHi dlim,
thanks for getting back to me.
I will try to upgrade the design to the latest Quartus Version and see what happens,
further I have checked the link without autonegotiation. When I disable AUTONEG
in the PCS and the switch port my board is connected to I can estalish a connection
and exchange data, so this problem seems to be only related to the autoneg process
but not the data exchange itself.
Andre
