AHart2
7 years agoHello, is there an know problem with the 1000Base-X autonegotiation in the PCS_PMA unit of the triple speed ethernet mac ? Best regards, Andre
The design is compiled with Quartus 16.0 for CYCLONE V SOC with transceivers I follow the PCS initialization scheme suggested in the TSE user manual and have already tried the workaround suggested...
Deshi_Intel
7 years agoHi Andre,
I checked the KDB link and I can see below are 2 other factors that may affect TSE auto-negotiation. Feel free to check it out.
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/solutions/rd09082010_546.html
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/solutions/rd02282012_17.html
General recommendation is to always try out latest Quartus version as there will be more issue fixed update in latest Quartus version.
dlim
- AHart27 years ago
Dear Dlim,
thanks for your reply, that was much faster than I expected !
I have carefully read the articles, for the first KDB answer I can assure that AUTONEG is enabled on
both sides - the PCS and the switch, so this is not causing the issue.
Regarding the second KDB answer ( incorrect device availability advertized ) I'm not sure if this has
been fixed in the current quartus version. The KDB article is dated from 2012 - I have compiled my
design with Quartus 16.0 and also tried 16.1 both without fixing the problem. Is there something
like a list of release notes where I can see which issues have been fixed and which are still open ?
All the best!
Andre
