14 years agoGUI of 'pci express high performance reference design'
Hi, I am using audio video dev kit stratix iv edition. Last week I want to program it with pci express high performance reference design. Problems as shown belows arised. 1. PC cann't intall the...
13 years ago --- Quote Start --- Yesterday I faced the same problem. I found the solution. Though you install the Jungo driver windows is not able to realize that this is the one for the new PCI device. You have to assign the driver manually. So select manual install, list all devices, select the Jungo category and than select altera/PCIe performance demo. It worked for me with both reference design. --- Quote End --- Hi, Are you using the Cyclone GX board? I get Stratix IV GUI for Perfomance demo, and when I press scan motherboard PCI bus gives message "Unable to detect a PCI express board compatible with this software application" . Is there any other application to be run for Cyclone IV? I programmed the FPGA with ...\C4gx15_starter_qsys_pcie_gen1x1\c4gx_qsys_pcie_gen1x1\top.flash . Thanks
