15 years agoGetting uC/Probe working with BeMicro SDK
I'm working through the BeMicro SDK tutorial, and I'm at Module 6: Instrument the Design using uC/Probe. I run through the setup in Module 6 with no problem, but at step 6.4, "Press the play button t...
14 years agoA month late, but figured worth noting...
I had the same issue and I couldn't find the document noted earlier either, but on another thread at: http://ez.analog.com/thread/11004 I found this tidbit: “After installation add to the “Path” system variable the entry ”%QUARTUS_ROOTDIR%\bin\“ on the third position in the list”. In my case, I just added it to the QUARTUS entry at the of my Path and I was able to get everything to get the uCProbe numeric and scale monitoring of the temp sensor to work in the BeMicro SW lab (lab1.c). Hope this helps.
