15 years agoGetting uC/Probe working with BeMicro SDK
I'm working through the BeMicro SDK tutorial, and I'm at Module 6: Instrument the Design using uC/Probe. I run through the setup in Module 6 with no problem, but at step 6.4, "Press the play button t...
15 years agoI found the answer myself. The "Installation Utils & Issues to Avoid" folder had a document named uCProbe Setup - Fix.doc, which said the problem was that Quartus bin wasn't in the path. When I added it to the path, everything worked.
