16 years agoGetting multiple fan-out errors when compiling a scratch Nios with DDR SDRAM support
Hi, I'm new to FPGA, working with the Altera CIII Dev Kit. I've created a base Nios system running from on-chip mem, successfully controlling pio's via SW. Now I went to add DDR SDRAM supp...
16 years agoHi again,
Turned out that I was using the term 'correctly' a bit cassually! The error came from the fact that I had assigned bidirectional ports on the Nios to output-pins instead of bidir-pins! Cheers, Erik
