8 years agoFrustratiopn getting the DE0-Nano control panel to work.
New here! Just got a DE0-Nano. Real frustration from the get go! Cannot even get the DE0-Nano control panel to work. I installed the Altera FPGA (free) development tool Quartu2 II Prime 18. ...
8 years agoGo to cd download page to faq page to common technical questions.
The following questions and answer point to pdf downloads that when applied solved the same problem that you were having. How to Update CD Demo Batch Files for Newer Quartus Edition ? Running Control Panel under Quartus II 15.0 or later version I tested the Control Panel updates for version 16.1 and 18.0. Under 16.1 I had a download failure (execution path incorrect). I typed the command in a terminal window, made the path fix, ran it. and it fix the problem. I did not test the demo programs. jjfretired
