12 years agoFPGA on DE0-Nano accessing the EPCS64
The zip file (http://www.alteraforum.com/forum/attachment.php?attachmentid=6881&d=1362294043) in this post (https://www.alteraforum.com/forum/showthread.php?p=163922#post163922) contains a single VHD...
12 years agoHere's what I just did using the files in the zip you linked to;
1. Open scripts/constraints.tcl and uncommented the EPCS pin assignments 2. Open src/de0_nano.vhd and uncommented the ports on the entity and the output signal assignments (near the end of the file) 3. Started Quartus 12.1sp1, and sourced the synthesis script using the Tcl console. This produces the error messages
Info (169141): DATA dual-purpose pin not reserved
Error (169187): Following feature(s) of I/O pin epcs_csN has invalid setting(s) in the configuration scheme ACTIVE_SERIAL when the pin is placed at pin location D2
Info (169189): I/O feature 'Current Strength' has an invalid setting. The setting should be Default.
Error (169187): Following feature(s) of I/O pin epcs_sck has invalid setting(s) in the configuration scheme ACTIVE_SERIAL when the pin is placed at pin location H1
Error (169187): Following feature(s) of I/O pin epcs_mosi has invalid setting(s) in the configuration scheme ACTIVE_SERIAL when the pin is placed at pin location H2
Info (171121): Fitter preparation operations ending: elapsed time is 00:00:02
Error (171000): Can't fit design in device
This error is related to an invalid setting, so modify the constraints file so that the drive and slew rate settings are left at their default
# EPCS
# The EPCS interface can only be used if the device is
# *not* setup to configure in Active Serial mode.
set pin(epcs_csN) {PIN = D2}
set pin(epcs_sck) {PIN = H1}
set pin(epcs_mosi) {PIN = H2}
set pin(epcs_miso) {PIN = C1}
the design will now synthesize correctly. So my recollection above was backwards, in that it is PS mode that is the problem. To see that, do the following ... 4. Select Assignments->Device, Device&Pin Options, and select Configuration. Change the mode to Passive Serial, and then press the "Play" button in the Quartus GUI.
Error (176310): Can't place multiple pins assigned to pin location Pin_H1 (IOPAD_X0_Y22_N0)
Info (176311): Pin epcs_sck is assigned to pin location Pin_H1 (IOPAD_X0_Y22_N0)
Info (176311): Pin ~ALTERA_DCLK~ is assigned to pin location Pin_H1 (IOPAD_X0_Y22_N0)
Info (171121): Fitter preparation operations ending: elapsed time is 00:00:00
So PS mode does not allow you to define DCLK as an output, which makes sense, since an external configuration host is supposed to drive that pin. Cheers, Dave
