9 years agoFPGA hardware result different from simulation
Hi, I may be wrong, but I think this is where I should post this question. I'm working with the max10 development board . https://www.altera.com/products/boards_and_kits/dev-kits/altera/max-...
9 years agoHi GooGooCluster,
Thank you for the response. I figured it out. I messed up at the third point, the reset signals. I also ran into problems with setting/changing duty cycle and after some time, was a result of not debouncing. I have verified everything to be working, so the points you described were on point. =] I will look for the code tags in the future, thanks! I would consider this resolved, do we need to flag this thread or anything?
