Lambert
6 years agoFPGA can work at >500Mhz?
Hi everyone, If my design which use less resource of FPGA, it can run more than 500Mhz? For example, my fpga is Arria V, my design use resource less than 15%, and I only need few resource to r...
ak6dn
6 years agoWhat does the data sheet say as the max clock frequency spec for the device you have?
That will give you an upper bound. Actual logic and routing delays will likely degrade that number as an actual max clock frequency.
- Lambert6 years ago
Hi ak6dn,
Do I need to view the max frequency of max clock tree (globle clock and regional clock)? Or other thing? Like the below fig:
B.S.
Lambert
