FPGA- SDC creation for 0.00039MHz clk
- 1 year ago
Instead of using a slow clock for your sensor detection module, you update it only when clk_en is high:
always @(posedge clk or negedge reset_n) begin
if (!reset_n) begin
sensor_state <= 0;
end else if (clk_en) begin
sensor_state <= sensor_input; // Sample the sensor input at 390 Hz
end
end
If you need to detect a rising edge of the sensor input, you can do:
reg sensor_prev; always @(posedge clk or negedge reset_n) begin if (!reset_n) begin sensor_prev <= 0; end else if (clk_en) begin sensor_prev <= sensor_input; end end wire sensor_rising_edge = clk_en & sensor_input & ~sensor_prev;
This will trigger a pulse only when the sensor input rises at 390 Hz.
As we do not receive any response from you on the previous answer that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
