FPGA- SDC creation for 0.00039MHz clk
- 1 year ago
Instead of using a slow clock for your sensor detection module, you update it only when clk_en is high:
always @(posedge clk or negedge reset_n) begin
if (!reset_n) begin
sensor_state <= 0;
end else if (clk_en) begin
sensor_state <= sensor_input; // Sample the sensor input at 390 Hz
end
end
If you need to detect a rising edge of the sensor input, you can do:
reg sensor_prev; always @(posedge clk or negedge reset_n) begin if (!reset_n) begin sensor_prev <= 0; end else if (clk_en) begin sensor_prev <= sensor_input; end end wire sensor_rising_edge = clk_en & sensor_input & ~sensor_prev;
This will trigger a pulse only when the sensor input rises at 390 Hz.
I believe that it is because you are constraining the clock to be too slow that is causing this problem. My suggestion is for you to use clock enable instead:
Example 1:
- reg [16:0] counter; reg clk_en; always @(posedge clk or negedge reset_n) begin if (!reset_n) begin counter <= 0; clk_en <= 0; end else if (counter == 127999) begin // Divide 50 MHz to 390 Hz counter <= 0; clk_en <= 1; end else begin counter <= counter + 1; clk_en <= 0; end end. Adjust 127999 if using a different base clock frequency.
Example 2:
Use the generated clk_en to enable the logic that would typically run on the 390 Hz clock:
verilog
always @(posedge clk or negedge reset_n) begin if (!reset_n) begin slow_logic_state <= 0; end else if (clk_en) begin slow_logic_state <= next_slow_logic_state; end end
In my design, the slower clock is used as clock for one module, in this rising edge we are detecting the sensor input.
if we use the clk_en method how do we use this signal as clock?
Abinaya
