FPGA- SDC creation for 0.00039MHz clk
- 1 year ago
Instead of using a slow clock for your sensor detection module, you update it only when clk_en is high:
always @(posedge clk or negedge reset_n) begin
if (!reset_n) begin
sensor_state <= 0;
end else if (clk_en) begin
sensor_state <= sensor_input; // Sample the sensor input at 390 Hz
end
end
If you need to detect a rising edge of the sensor input, you can do:
reg sensor_prev; always @(posedge clk or negedge reset_n) begin if (!reset_n) begin sensor_prev <= 0; end else if (clk_en) begin sensor_prev <= sensor_input; end end wire sensor_rising_edge = clk_en & sensor_input & ~sensor_prev;
This will trigger a pulse only when the sensor input rises at 390 Hz.
if timing analysis detects an incorrect or not implementable constraint, it adds a message to timing analysis report. It should explain why your generated clock isn't accepted.
I wonder what's the purpose of a 390 Hz clock in your design. In most cases, we'll use a clock enable in the respective master clock (26 MHz) domain instead, keeping a single synchronous clock domain.
this value is used for some slower clk sensor rise fall detection. I need three slow clocks
