FPGA- SDC creation for 0.00039MHz clk
- 1 year ago
Instead of using a slow clock for your sensor detection module, you update it only when clk_en is high:
always @(posedge clk or negedge reset_n) begin
if (!reset_n) begin
sensor_state <= 0;
end else if (clk_en) begin
sensor_state <= sensor_input; // Sample the sensor input at 390 Hz
end
end
If you need to detect a rising edge of the sensor input, you can do:
reg sensor_prev; always @(posedge clk or negedge reset_n) begin if (!reset_n) begin sensor_prev <= 0; end else if (clk_en) begin sensor_prev <= sensor_input; end end wire sensor_rising_edge = clk_en & sensor_input & ~sensor_prev;
This will trigger a pulse only when the sensor input rises at 390 Hz.
What does your base create_clock constraint look like? You can't create a generated clock if the base clock it references isn't constrained as well. The report there shows the base clock as unconstrained.
base clk is FPGA_CLK which is already constrained.i don't know why the divider[15] is taken as the base type
