PaulWW's avatar
PaulWW
2 years ago
FMC and FMC+ connector compatibility
Hello, I'm trying to understand compatibility between FMC+ and FMC connectors. The Intel Agilex FPGA M-Series Dev Kit HBM2e Edition (DK-DEV-AGM039FES) has a 560-pin (14x40) FMC+ connector. Is this compatible with a 400-pin (10x40) FMC connector, such as the one on the TI ADS54J66EVM evaluation board?
  • If I read this correctly ... https://www.samtec.com/standards/vita/fmc-plus/
    there is a degree of backward compatibility. From the second section:
    " While new FMC+ cards can only plug into new FMC+ carriers due to their larger connectors, original FMC cards will also fit thanks to a customized polarization system providing true backward compatibility."
    So if you have an existing FMC daughtercard you should be able to insert it into your new FMC+ FPGA board.
  • _AK6DN_'s avatar
    _AK6DN_
  • NazrulNaim_Intel's avatar
    NazrulNaim_Intel
    Sorry for the delay. As user '_AK5DN_' have provided the response. The response can be accepted. For more information regarding the FMC+ connector can be accessed through the link below.
    Link : A.5. Communication Interfaces (intel.com)
    Hope that answers your question.
    Nazrul Naim
    NazrulNaim_Intel
    I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
    If this does address your question, please take a moment to close this service request from your mySupport account and fill out the service evaluation survey. If you feel your support experience was excellent, please rate it with score of 10. If you feel your support experience was less than a 9 or 10, please allow me to correct it before closing or please let me know the cause so that I can improve your future support experience.
    Nazrul Naim
