FMC and FMC+ connector compatibility
- 2 years ago
If I read this correctly ... https://www.samtec.com/standards/vita/fmc-plus/
there is a degree of backward compatibility. From the second section:
" While new FMC+ cards can only plug into new FMC+ carriers due to their larger connectors, original FMC cards will also fit thanks to a customized polarization system providing true backward compatibility."
So if you have an existing FMC daughtercard you should be able to insert it into your new FMC+ FPGA board.
