thorax58
5 years agoFlexRAN reference # SCSY-36054 (SIB1 decoding issue)
Is it possible to get the conditions under which SCSY-36054 occurred (error decoding SIB1 when CellId={1,3,5}) in FlexRAN 20.11).
I'm having a CRC failure when decoding SIB1 using FlexRAN 21.03 but...
CheepinC_altera
5 years agoHi,
As I understand it, you seems to have some inquiries specific to the FlexRAN 21.03. For your information, FlexRAN is not specific to FPGA. I am currently consulting internal on the right path to route your case to the FlexRAN team.
Just to check with you if you have IPS access? If yes, you can open an IPS case and select FlexRAN product so that it could be routed the FlexRAN team.
Chee Pin
