FlexRAN reference # SCSY-36054 (SIB1 decoding issue)
Hello thorax58
Thank you for posting on the Intel® communities.
In order to check this further and provide the proper information, could you please confirm the following details?
1- Are you referring to IIntel® FlexRAN reference architecture?
2- Are you developing or integrating 5G network devices?
3- Are you using other Intel® components in regards to this request? For instance, Processors or Wireless cards? Could you please provide the exact model of those components?
4- Could you please elaborate more regarding what you are trying the achieve and the issue that you are having?
Andrew G.
Intel Customer Support Technician
- thorax585 years ago
Hi Andrew. I'm referring to the Intel FlexRAN Reference Architecture, specifically the Release Notes for version 21.03.1 (639554-2.6.1-flexran-ref-solution-sw-release-note-v21.03.1.pdf). On page 126 there's a known issue in version 20.11 describing a SIB1 decoding error when using CellId={1,3,5} with reference # SCSY-36054.
I would like to know more details about the conditions under which this error could occur. I did not see this error in 20.11 but am seeing something similar in 21.03, despite it being noted as fixed for 21.03.
I am working on a 5g device using N3000 cards and am trying to do a UE attach. This works under 20.11 whereas I haven't got it to work under 21.03 yet.
At this stage I'm just doing my own due diligence and would like to know more details about SCSY-36054 to see if it's relevant to my situation. If it's not, I will pursue the regular support channels.
