AleksaPanic
5 years agoFlexRAN - None FPGA found!
Hi, We are working on the FlexRAN system and according to the FlexRAN 5GNR Reference Solution 20.08 (Document #603577) we should be able to execute tests on TestMac, but we are getting the same erro...
thorax58
5 years agoWould also like to know if there was a resolution to this. Or hints to troubleshoot? Thanks.
- JET602005 years ago
Contributor
for FelxRAN v20.08 Release, if you r using "<dpdkBasebandFecMode>0</dpdkBasebandFecMode>" in Phycfg_Radio.xml, that means you will use DPDK software FEC module to execute your test, instead if using Hardware FEC Accelerator Card.
