11 years agoFlash programming guide for DE0-NANO needed.
Hi. I have been searching around in the forum. I found a few discussions regarding the flash programmer issues. I have found the NiosII Flash Programmer Guide and the EPCS IP differs from t...
11 years agoHi Experts.
I Finally solved several of my problems. I found out what to do with the conduit. I can now flash program the software to the configuration memory. But the code will not start, and it looks like configuration memory looses the SOF data. Because the leds on the board starts to glow in the same way when the leds are unused. And I flash program two times because of the dual-core construction. I have one IP epcs-flash-programmer in the hardware construction connected to both CPU-cores. Am I missing something? What do I do wrong?
