SPere43
6 years agoFix an error
Hello guys. Im try compile a example hello_world in a kernel. But i have a error: Error: Qsys-script FAILED. I already checked the forum, but I didn't find any compatible solution. Intel FPGA SD...
MEIYAN_L_Intel
6 years agoHi,
May I know do you using the terasic board: DE1-SOC as I found the information from the .log file.
It seems like that board BSP is not compatible with Quartus v19.1.
Could you try to check the instructions provided by terasic to see the version of Quartus used that is compatible with your BSP.
SPere43
6 years agoI found this in FPGA bsp document:
