VSavi3
5 years agoFifo simulation
Hi, I am using altera libraries cells to run simulation of my design in synopsys vcs. Basically few fifo and memories I use. I compile altera_mf.v file for this purpose. The compilation is going wel...
VSavi3
5 years agoHi,
I here with attached the compile log of the simulation, Please scroll down till end you will find continuous display of " is not a hexadecimal value".
Any help is greatly appreciated.
Vikram
RichardT_altera
5 years agohi, without a design, it will be hard to determine why this error occur. please help to share your design so we could check on this. If your design is confidential, a simplify design that could duplicate the error will good enough for investigation.
You may checkout the fifo user guide below along with the design example (at page 30):
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_fifo.pdf
