MikeMot
1 year agofgpa pins to use the LED in the devkit AGilex 7 f tile I series AGIB027R31B1E1VB
In the user Guide for the agilex 7 I series transceiver soc dev kit . All of the user_leds seems to be used for configurations. Are those available for a user to use and programm them using r...
ShengN_altera
1 year agoHi Mike,
If check these links https://www.intel.com/content/www/us/en/docs/programmable/709314/24-1-19-7-3/interface-signals-08789.html and https://www.intel.com/content/www/us/en/docs/programmable/710496/22-1-19-2-1/signal.html
SGPIO slave signals. These groups of signals connect to the MAX device to control the on-board LEDs
Those are the signals to control the MAX 10 LEDs. I think they're not reserved for specific function. BTS config using those signals to control the LEDs as well. You can try the simple design and should see the LED blinking.
So far, those are the LEDs can be found on the board.
Sheng
