Isnan
5 years agoFFT IP not working
Dear All,
I did some projects using FFT IP to process 20Khz signal from two-channel 5MSPS simultaneously ADC. however, the FFT IP from my design is not working properly. The source_imag of FFT Ip i...
CheepinC_altera
5 years agoHi,
Just to follow up with you on this. Thank you.
Isnan
5 years agoHi CheePin,
yeah, still stuck to the last problem, I can't get a signal that represents real and imaginer. I think the sampling data needs some pre-processing or signal conditioning before wiring to FFT IP. btw I did a simulation using Matlab Simulink and the output is good as expected. well, I need to learn more about this FFT IP.
