FFT IP not working
Thanks for your update. Since the hardware observation is matching the FFT, it means that the behavior of the FFT is something expected. I would suggest for you to look into your input data source to check if it only consist of real data or it is consisting of both real and imaginary.
- Isnan5 years ago
I am sorry I don't understand about matching the FFT, what should I do with input signal? do I need pre processing before FFT?. my input data for sink_real is directly from ADC sampling, whereas for sink_imaginer is zero. basically I expect output that contains spike represent frequency and magnitude. however, the FFT output is still in sinusoid type.
Anyway,, I will try again with several input variations.
Thank you very much.
