Isnan
4 years agoFFT IP not working
Dear All,
I did some projects using FFT IP to process 20Khz signal from two-channel 5MSPS simultaneously ADC. however, the FFT IP from my design is not working properly. The source_imag of FFT Ip i...
Isnan
4 years agoDear Chee Pin,
Thank you for your reply,,
after your suggestion, I try to simulate using ModelSim, and the result is similar to real hardware, please see the figure attached.
I think the sop and eop signals are correct. I still can't understand why.
Also, I attach the full Quartus project of FFT simulation (.rar), hopefully you (or anyone) can help me to find the problem. Thank you
Sincerely,
Isnan
