Isnan
5 years agoFFT IP not working
Dear All,
I did some projects using FFT IP to process 20Khz signal from two-channel 5MSPS simultaneously ADC. however, the FFT IP from my design is not working properly. The source_imag of FFT Ip i...
CheepinC_altera
5 years agoHi,
As I understand it, you have some inquiries related to the FFT IP. Just to check with you if you have had a chance to run a Modelsim simulation with the FFT IP. This would be helpful to narrow down any functional related problem prior to hardware testing.
Chee Pin
