pp
5 years agofft_ip核仿真,接口时序问题
我使用的软件版本是2018.1 pro专业版
在对FFT IP核进行仿真时,对其时序产生疑问,请各位帮我看看,我输入的信号时序,哪里给错了,为何输出的source_error会给2b'11的值
IP核的配置如下
请求帮忙,卡了好久了,实在不知道哪里出了问题
CheepinC_altera
5 years agoHi,
As I understand it, you observe some issue when trying to simulate with FFT IP. For your information, I have generated the example test bench using Q17.0Std mimic your IP configuration. I am able to run the simulation without error. I have attached the simulation files for your reference. You can try to look into it and cross check with yours to see if can spot any anomaly.
To run the simulation:
1. Open Modelsim and change directory to simulation_scripts\mentor
2. "source msim_setup.tcl"
3. "ld"
4. "do wave.do"
5. "run -all"
pp
5 years ago前辈您好,您给的例程,我已经进行仿真了,下图是您的仿真波形
接下来是我的工程的仿真波形
我没有看出有何不同呢,前辈,您能否帮我看看,指点我一下
